Re: IH 1066 HYDRAULIC PROBLEM..
Posted by bermuda ken on August 26, 2003 at 14:54:16 from (64.73.6.171):
In Reply to: IH 1066 HYDRAULIC PROBLEM.. posted by MITCHELL DABBS on August 26, 2003 at 13:03:40:
If the pto failed, you have worn the splines off of the PTO input driveshaft and or pressure plate. You need to split the tractor at the clutch housing and replace the clutch, PPA, PTO input shaft, seals and o-ring to fix this.
This is not a hydrualic problem, instead, the shaft splines that DRIVE the hydraulics and pto is just worn out.
Post A Followup
: Re: Re: IH 1066 HYDRAULIC PROBLEM..
