Re: Re: Re: Re: Second generator still no charge-H
Posted by Bob Quale on August 29, 2003 at 09:28:29 from (68.63.103.222):
In Reply to: Re: Re: Re: Second generator still no charge-HELP! posted by Dakota Jim on August 29, 2003 at 05:41:06:
OK I got it to work but i'm not sure why. I put my voltmeter from A to ground. I then repolarized the generator and watched the VOM. Each time I touched the terminal for polarization, the VOM raised about .5 volts. I did it untill I got max voltage, about 10 times?. Then I ran a wire from the F to ground and the ameter shows it is charging, with out this wire it will not charge so I will get another regulator and see how I make out.
Thanks for all the help!
Post A Followup
: Re: Re: Re: Re: Re: Second generator still no charge-H
