Re: What should My piston rings look like
Posted by EZ on September 03, 2003 at 17:37:25 from (216.211.7.57):
In Reply to: What should My piston rings look like posted by Bob Quale on September 03, 2003 at 13:46:12:
There are a few things to consider before swapping out rings, pistons, etc...First you must determine if they are original size, i.e. have the cylinders been bored oversize etc...There are clearances to be measured, etc...
Firstly you could check your compression, if compression is up to spec. and the cylinder walls don't look scored, then you should be OK.
Try this link for engine work fundamentals.
Post A Followup
: Re: Re: What should My piston rings look like
