Re: Oiling Problem
Posted by Haas on September 28, 2003 at 12:23:05 from (12.65.78.200):
In Reply to: Oiling Problem posted by Kevin In Michigan on September 28, 2003 at 10:18:06:
As Parts Man said, the center stud of the three that holds the rocker assembly is drilled so that oil comes up through the bottom of it and goes out the side into the rocker shaft. Hole must be turned correctly and of course must be there. I tried to get this stud from my IH dealer and he said was no longer available. I had to get one at an Auto Parts dealer and then drill in myself.
Post A Followup
: Re: Re: Oiling Problem
