3414 Brakes
Posted by Mike on October 01, 2003 at 13:31:18 from (192.249.47.9):
I have a 3414 diesel TLB and the brakes leave a lot to be desired. I have replaced the brake discs (OEM parts), replaced the worn balls and generally freed up the linkage system, the diff seals don't leak, yet it is darn near impossible to stop this tractor on a grade. Any suggestions would be appreciated.
Post A Followup
: Re: 3414 Brakes
