Farmall Tractors Discussion Board
Re: SMTA HYDRAULICS
Posted by Ronnie on September 28, 1999 at 07:49:29 from (208.30.90.114):
In Reply to: SMTA HYDRAULICS posted by MIKE on September 27, 1999 at 19:20:24:
You will need to install the two way valve. The short rod is your one way. Then you should have a long rod that goes to the two way valve. It's mounts at the front right fuel tank bolt and down on the clutch housing. My Super M-TA Diesel's hydralics work fine.
Post a Followup
: Re: Re: SMTA HYDRAULICS
