Leaking Bolts on Pan of Farmall B
Posted by Roger on October 04, 2003 at 18:22:38 from (69.58.144.122):
I just finished restoring a Farmall B and for some reason I am getting oil leaking out of several of the pan bolts. It only leaks when I run the engine, which I suppose is just from the oil being slung around in the block. I know some of the taped holes for the pan bolts may go through, but I haven't had them leak on other tractors. I used a silicone sealant on the pan gasket so there are no leaks through the gasket. I am thinking of pulling out the bolts that leak and coat them with non hardening Permatex. Have others had this problem? Roger
Post A Followup
: Re: Leaking Bolts on Pan of Farmall B
