Re: Leaking Bolts on Pan of Farmall B
Posted by Jonathan Mirgon on October 05, 2003 at 01:30:40 from (205.208.129.146):
In Reply to: Leaking Bolts on Pan of Farmall B posted by Roger on October 04, 2003 at 18:22:38:
I have an (a) and am having the same problem, I knew that the pan bolts were not blind so I coated all the pan bolts with silicone, And they are right through the silicone away it doesent work mine still leak, I am too still looking for a solution.
Post A Followup
: Re: Re: Leaking Bolts on Pan of Farmall B
