Re: Re: Gear Reduction Starters
Posted by RayP(MI) on October 09, 2003 at 17:35:07 from (216.46.197.200):
In Reply to: Re: Gear Reduction Starters posted by RayP(MI) on October 09, 2003 at 17:29:07:
If you're running 6volts, can you change to 12volts? You can run same starter, have lots more kick, just don't crank too long.
Post A Followup
: Re: Re: Re: Gear Reduction Starters
