Re: SUPER A STILL NOT RUNNING
Posted by Gary_N_WV on October 14, 2003 at 05:32:34 from (129.71.234.254):
In Reply to: SUPER A STILL NOT RUNNING posted by BILL IN VT on October 14, 2003 at 03:25:41:
I don't know anything about mags, but if you have a coil distributor..........
Did you check to see if you are getting "fire" from your coil?
Take the end of the coil wire that plugs into the distributor cap and hold it about a 1/16 inch away from metal on the engine block and then crank the engine to see if you get spark.
There are a lot of very knowledgeable people on this forum, if you post back with results you get from all the suggestions, they will soon have you "running"
Good luck !
Post A Followup
: Re: Re: SUPER A STILL NOT RUNNING
