Re: Re: Farmall AV's
Posted by Slowpoke on October 15, 2003 at 00:45:51 from (67.30.99.28):
In Reply to: Re: Farmall AV's posted by Reid from CA on October 14, 2003 at 17:34:13:
If you don't have the crank, try turning the fan while putting pressure on the fan belt. If it's free, the crankshaft pulley will turn. If free with 3 point, $1000. If it's free, standard lift, 600-800. If it's frozen, 400-450.. Put the tranny in each gear and rock it with the rear wheel. The fan should turn (if the engine is free). Good luck.
Post A Followup
: Re: Re: Re: Farmall AV's
