Re: Rear axle on Farmall A
Posted by Hugh MacKay on October 19, 2003 at 13:15:57 from (64.228.11.60):
In Reply to: Rear axle on Farmall A posted by Frank Zmigrodski on October 19, 2003 at 08:13:13:
Frank: Do you have the gear oil pan off the bottom of the final drive. When you mention about the axle coming about 1/2" my thoughts are you may have some wear in spline on axle and bull gear may be what is holding the axle If worn in the section of spline in the bull gear, that may be problem.
My thoughts are if it moves 1/2" the bearing must have moved some. I think I would remove the final drive from tractor, then you could suspend the final drive on it's side with axle hub down or up for that matter. Move the axle back and forth the 1/2" This should give you better view of what is sticking and where. With the use of a small punch try sliding bearing back the 1/2". With the final drive suspended on two blocks and axle hanging down you could use a brass punch or hardwood block to hammer on inner end of axle. Key here is not hit anything very hard. You may have to move it back and forth the 1/2" several times. A lot of patience is in order. Let me know how you make out.
Post A Followup
: Re: Re: Rear axle on Farmall A
