Re: 706 Transmission Question
Posted by the tractor vet on October 19, 2003 at 15:22:57 from (216.196.13.75):
In Reply to: 706 Transmission Question posted by Farmall Don on October 19, 2003 at 09:59:51:
The dump valve is out of adjustment along withe the clutch and trans brake . First adjust the free travel of the clutch then the trans brake then the dump valve , Have someone hold the clutch pedal down to where it is ( one Inch off the stop from the floor plate) back off the dump valeve adjustment bolt till the oil lite comes on then start to turn it in till the lite goes out then add one turn and lock it down with the lock nut. It will shift a lot better then.
Post A Followup
: Re: Re: 706 Transmission Question
