Re: Re: M piston size and turbo
Posted by Troy - MI on October 23, 2003 at 14:29:45 from (216.65.163.74):
In Reply to: Re: M piston size and turbo posted by Dr.EVIL on October 22, 2003 at 07:33:01:
In order to change the firing order, you'd have to change the crankshaft too. For instance, if your order changed to 1-4-2-3, piston 1 and 2 would have to be in the same position in the sleeves. Same with 3 and 4. OEM engines have pistons 1 with 4 and 2 with 3. How do you accomplish this? Do you mill a new crankshaft? Sounds like a lot of work!
Post A Followup
: Re: Re: Re: M piston size and turbo
