Re: C died and won't start
Posted by old on November 03, 2003 at 14:51:16 from (63.190.97.139):
In Reply to: C died and won't start posted by Steve Mason on November 03, 2003 at 14:39:48:
I'd first pull the coil wire off the cap and check if you have spark. Hold the wire close to some metal and turn the engine over you should get spark. If not you have wireing problems, ie bad coil bad points etc. If you have spark go to the carb, pull the drain plug off the bottom if you have gas there good. From there I'd remove the air intake tube from the carb and see if you have a lot of gas in the carb. If not hold your hand over the end of the carb for a moment and turn the engine over at the same time, if it trys to fire you need to clean the carb. Hope this helps you some
Home
| Forums
Today's Featured Article -
Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our
... [Read Article]
Latest Ad:
1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
