C died and won't start
Posted by Steve Mason on November 03, 2003 at 14:39:48 from (209.163.2.76):
I knew the day would eventually come. My C (123ci engine) has started right up for me every single time since I got her almost 2 yrs ago. Yesterday I went to start her - started right up, ran about 3 or four minutes and died like somebody shut off the key.
I pulled the gas line off the card and fuel is coming through fine. I did notice some gas leaking around the choke lever on the side of the card but I figured maybe I had flooded it. I let it sit with the battery charger on it for a couple hours and tried to start it again. No luck.
I pulled the dist cap off and it looks like new.
Not sure where to go from here - points look OK.
Is there something that typically causes a tractor to just die? I'm thinking electrical but what do I check?
I figured this would be the first place I'd ever come to if I had a problem...and it is
Post A Followup
: Re: C died and won't start
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
