Re: C died and won't start
Posted by Farmer Bob on November 03, 2003 at 16:58:26 from (64.113.13.15):
In Reply to: C died and won't start posted by Steve Mason on November 03, 2003 at 14:39:48:
Good post below, I'd be suspect of the coil or condensor whether mag or dist. Condensors tend to either work they don't work. Coils can get weak with use and age or even give out between the primary and secondary circuits in them. It could also picked up a piece of debris which plugged a spot in the carb. Do the easy tests first then the more difficult and costly tasks.
Post A Followup
: Re: Re: C died and won't start
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
