Re: C died and won't start
Posted by Hugh MacKay on November 03, 2003 at 18:09:56 from (209.226.106.167):
In Reply to: C died and won't start posted by Steve Mason on November 03, 2003 at 14:39:48:
Steve: How is Iowa fall weather treating you? How did the crops turn off in the end? Last I heard from you it was very dry. On the C if it sounds like someone turned the switch off, maybe that is just what you should check first. Check for power coming from switch to coil with switch on. There was a guy on here couple days back and that wire from switch to coil had broken. I doubt if the coil is problem as they tend act up when tractor is at operating temp and then will work again when cool. Could be in points or condencer. A couple of other problems I've had over the years is a loose distributor shaft. Tractor would stop if it hit a bump or other jolt. With that it would always restart right away. The other is striped gears on distributor drive. I have seen them strip completely, thus if points are open you have no fire. I have also seen them slip a few teeth on drive thus throwing timing off. My first two thoughts would be power to coil and points and or condencer. May as well change both as just one. I will also tell you this, I have much better luck with ignition parts from CaseIH than other sources. I have seen ign parts from other sources that didn't fit right, didn't work well and didn't last long either.
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
