Re: Re: Super M - sputtering, barely running
Posted by bbauman on November 11, 2003 at 22:25:43 from (166.50.112.101):
In Reply to: Re: Super M - sputtering, barely running posted by Dan on November 11, 2003 at 17:23:01:
Spent some more time on it. The points have a greenish white coating and are pitted but were gapped correctly. They only have about 10 hours on them. I could find no resistor in the line but did not trace it all the way back either. Where is it normally located? If I don't have one, where should it go and where do I get one? Can't get to an IH dealer for a couple weeks.
My coil says "Only use with resistor" right on it. I did just get the tractor but have hard time believing somebody used it without the proper setup. The non-factory wiring is quite old appearing so my guess is it has been some time since the 12v conversion.
Post A Followup
: Re: Re: Re: Super M - sputtering, barely running
