Re: Re: Re: Super M - sputtering, barely running
Posted by Bob M on November 12, 2003 at 04:33:59 from (165.170.128.66):
In Reply to: Re: Re: Super M - sputtering, barely running posted by bbauman on November 11, 2003 at 22:25:43:
If you've got a 12 volt coil and no ballast resistor, there's a good chance the points have been overloaded and got burned; it may have also cooked the coil. You'll probably need to replace both components.
To keep it from happening again you need a resistor in series with the coil primary - ie between the ignition switch and the coil "+" terminal. Get a generic Chrysler-style resistor (NAPA #13ICR or similar - they cost about $5). When mounting the resistor remember it will get hot when the motor runs - keep it away from the gas line, other wiring, etc!
Post A Followup
: Re: Re: Re: Re: Super M - sputtering, barely running
