53 super m wiring follow up question
Posted by bob murphy on November 17, 2003 at 08:31:49 from (24.97.129.210):
Finally got the cover off and found a few things.
I had a broken ammeter wire and found a 12 volt generator. Brought it to my local rebuild guy who is matching up a delco alternator for me to replace the generator. My question is..
He says all I need to do is run the one wire from the alternator to the battery positive terminal. I believe he said there is a resistor built into the alternator. Then run everything else off of the battery.
Would this eliminate the need for the light and ballast resistor going to the coil?
Thanks in advance.
Post A Followup
: Re: 53 super m wiring follow up question
