Farmall Tractors Discussion Board
Re: Re: Re: Ammeter reading
Posted by Bob M on October 04, 1999 at 05:38:37 from (192.232.120.194):
In Reply to: Re: Re: Ammeter reading posted by Chris on October 03, 1999 at 19:51:18:
Your test indicates the generator windings are probably OK. First thing I would do then is replace those brushes. The brush wires have to carry the full output of the generator. If the wires are in bad shape (have a lot of resistance), it'll cause the cutout relay to chatter. Good idea to install a new cutout too when you replace the brushes.
Assuming the battery is in good shape and fully charged, and the generator and cutout are working correctly, a multimeter across the battery terminals should show:
6.2 to 6.3 volts with the engine off
6.8 to 7.5 volts with the engine running at max. RPM
Hope this helps...
Post a Followup
: Re: Re: Re: Re: Ammeter reading
