Re: IH 3444 backhoe special
Posted by JB on November 22, 2003 at 21:22:30 from (24.157.143.220):
In Reply to: IH 3444 backhoe special posted by LA Bill on November 22, 2003 at 10:21:58:
I have changed a CAV injector pump on a 434D which is the same BD154 engine as your backhoe. It was about 30 years ago and I will try to remember the steps. The method I used was take an awl and scratch a line around the injector mounting plate. You will also find a couple of timing marks on the engine plate by the bolt holes that the injector pump mounts to. To remove the injector pump you have to remove all the fuel lines and the timing gear cover on the fan side. Make sure you mark the timing gears or take note of where the factory marks are. Remove the nut on the shaft on the fan side of the timing gear. Remove the 3 nuts holding tne injector pump. Use a wooden mallet to tap the shaft out of the timing gear. There should be a key in the shaft. Reverse procedure to install new injector pump, making sure to use your scratch marks to align the new pump. Most cases if the new injector pump is install in exactly the same location as the old one the timing should be OK. If timing is to slow tractor will be hard to start, if timing is to fast engine will kick back on the start when starting. Timing is adjusted by loosening the 3 mount screws and rotating the injector pump a small amount. If I remember correctly rotating the injector pump toward the engine block will advance the timing. Good luck JB
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
