Re: Re: Re: No Steering on my H
Posted by Bob M on December 03, 2003 at 16:42:54 from (66.66.126.128):
In Reply to: Re: Re: No Steering on my H posted by tony on December 03, 2003 at 15:14:34:
Tony - At the bottom of the pivot shaft first there's a spacer (the piece that was missing on my tractor) then the thrust bearing. The thrust bearing has a "top" and "bottom". You can tell by inspection which is which - make sure you don't install the bearing upside down! The pivot shaft seals will remain in place when you remove the pivot shaft. Unless you're gonna replace the pivot shaft bushings you can simply leave the seals alone. The sector gear may be difficult to remove from the busted pivot shaft. It's on a tapered spline and usually requires several good licks from a fair sized hammer to break free. Be careful support the sector gear so as not damage it when knocking the shaft out! One more tip: Make sure the new pivot shaft is in the "straight ahead" position before installing the sector gear, and that the sector gear is centered on the worm gear. And remember to put the lower bolster mounting bolt with the extended head in the right front bolster flange bolt hole. Hope this helps!!
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
