Re: Engine heater
Posted by Bob on December 04, 2003 at 08:52:37 from (66.163.134.177):
In Reply to: Engine heater posted by Mike on December 04, 2003 at 07:39:32:
I consider block heaters the best, if you can get one for your appliaction.
As far as wattage, how are you going to use the heater... what is your coldest temp? Will the tractor be inside out of the wind, or shedded? Do you want to leave the tractor plugged in overnight, or do you want a high wattage heater that can warm a cold engine up in an hour or so in the coldest weather?
If you are going to leave the unit plugged in overnight, and don't have 20 below zero temps, a 600 watt heater will be more than adequate. Other wise, increase wattage accordingly.
Post A Followup
: Re: Re: Engine heater
