How Long Will An M Run On Battery Alone?
Posted by Scott on December 06, 2003 at 19:10:31 from (63.245.131.15):
I needed extra cranking power on a M tractor. I took the 6 volt battery off and replaced it with 12 volt. I then disconnected the generator, and put a resistor in line to the coil. The tractor cranks great and runs fine. The only thing is that it is not charging. I can always do this with a battery charger. Does anybody have an idea how long it will take for the points to run the battery down? I was told the points draw very little power.
Post A Followup
: Re: How Long Will An M Run On Battery Alone?
