M.D Throttle problem
Posted by Newt on December 09, 2003 at 14:19:32 from (205.188.209.82):
On my M.D It seems Iam not getting full throttle.As I have just purchased this tractor Iam not sure how much acelleration the the engine speed control lever should have. It seems the only throttle advance is from the middle position to full throttle and that is not very much. In full throttle it does not seem to really rev up. also the engine speed control handle seems really loose until you push it way up to full. Would air in the system maybe cause this situation. I know the filters were changed prior to me purchasing it. I dont know if he bleed the system. Any help would be greatly appreciated.
Post A Followup
: Re: M.D Throttle problem
