Re: Farmall M trans seal replacement HELP!
Posted by Ray M41 on December 15, 2003 at 07:44:00 from (129.113.26.59):
In Reply to: Farmall M trans seal replacement HELP! posted by Scott's big M! on December 14, 2003 at 21:22:56:
What I remember from mine is leave the shaft linkage coupled but the bolts and nuts loose. The clutch plate springs must be compressed as Haas said and unbolted from the flywheel. Make two hooks from flat strips of metal to reach in on the edges of the clutch plate and pull it out from the the inside of the flywheel. Let it side out on the splined shaft. Once the clutch plate is outside of the flywheel inset the shaft can then be unbolted and all will come falling down on your belly. to install it reverse the proceedure.
Hope this helps.
Post A Followup
: Re: Re: Farmall M trans seal replacement HELP!
