Farmall Tractors Discussion Board
Re: Farmall engine blocks, 264 or 281 ?
Posted by Harold H on October 06, 1999 at 17:37:26 from (207.244.59.20):
In Reply to: Farmall engine blocks, 264 or 281 ? posted by Drew Simpson on October 06, 1999 at 06:36:29:
As far as I know, the 4 1/8" pistons and sleaves, giving 281 cu inch are the largest bore sleaves that will fit either the 264 or 281 block as built. A LPG head is a good add on if you don't already have one. It has a 8.35 to 1 compression ratio and valve rotators as built vs a 6.6 to 1 compression for the gasoline head as built.
Harold H
Post a Followup
: Re: Re: Farmall engine blocks, 264 or 281 ?
