More Bad news with the C project....
Posted by Tommy H on December 20, 2003 at 16:02:39 from (65.141.63.140):
I pulled the manifold off and snapped a bolt off i nthe manifold. Finally got the manifold off. I removed the Rocker assembly and started removign the head. OH, before i pulled the head I ran a compression test. all were around 65 psi. Didnt right it down, but steadily at 65. Added oil to each cylinder and no change. Anyway pulled the head off and it has the fire crater pistons. They look NEW! The sleeves are as smooth as silk! No movement of the pistons in the sleeves. Remember how I said the block had been brazed on the left side. Well apparently it happened in side too. There is what appears to be a srip of Silver seal from the bolt holes between the 3 & 4 pistons up to the 3 sleeve, across and down passed the 2 sleeve, and down to the bolt holes between the 1 & 2 cylinders. There is a tiny hairline crack right in the middle of the silver seal job. Im wondering if it was silver sealed, then decked and the decking revealed the sealed crack, which is no problem. OR did it get silver sealed, then crack again? Is it ok? Is it the worlds largest paper weight now? But NO OIL in the water and no water in the oil. Im going to take the head and have it boiled, and have new valves installed, and have new seats put in, new guides the works! There is alot of carbon build up in the combustion chamber. only 1 plug was fouled. Im still perplexed about the Distillate/Gas set up. I have a Zenith carb with a petcock in the bottom in the back (by block) for draining the bowl, it has an adjust ment needle on the front of the carb facing out. And it has an adjustment facing down at an angel on the top. Choke rod goes on carb, near block. Float has 2 seperate bouys. IS it distillate or gas? Intake has rounded/squared runners. But has a box in the middle. Is it distillate or Gas?
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
