Re: Farmall H swinging drawbar strap or roller an
Posted by Hugh MacKay on December 22, 2003 at 18:26:22 from (209.226.247.153):
In Reply to: Farmall H swinging drawbar strap or roller and sh posted by john on December 22, 2003 at 15:12:49:
John: You could straighten that drawbar in a press. One of the first things we always did with a new tractor was weld a 3/4" thick bar across the cross bar section of the U. They were never heavy enough from factory. As to roller or strap it's your preference, originally roller was optional and was good at cutting down on wear if you were doing work allowing drawbar to swing. On the pin under tractor it was oversize from new, aprox 1/8 over. This must be loose to allow for flexing of drawbar. A tight fit will break transmission case.
Post A Followup
: Re: Re: Farmall H swinging drawbar strap or roller an
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
