Re: 12V Ignition troubles
Posted by Chuck's Repair on December 26, 2003 at 14:18:43 from (216.170.58.10):
In Reply to: 12V Ignition troubles posted by Jason on December 26, 2003 at 13:58:38:
Yes you need an external resisror.Without a resistor there is too much current flowing.The condenser does not have the capacity to handle the extra current flow and arcing of the points occurs.The extra current flow also will cause more heat in the coil itself which is oil filled and can burn up a coil in a short amount of time.
Post A Followup
: Re: Re: 12V Ignition troubles
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
