Re: Clutch disc install
Posted by Catskill Pete on January 06, 2004 at 20:34:10 from (205.232.37.115):
In Reply to: Clutch disc install posted by Craig Mullen on January 06, 2004 at 18:07:49:
Never never never trust factory presets on clutch plates etc, always check the settings. The plate may be set for some other application.
Post A Followup
: Re: Re: Clutch disc install
