Re: H bull gear removal
Posted by rebuilder on January 08, 2004 at 14:16:42 from (66.228.102.107):
In Reply to: H bull gear removal posted by ellson on January 08, 2004 at 14:01:42:
Ellson; One trick I have learned tearing apart junker tractors at a salvage yard is to grab the axle at the very end and wiggle it up & down as you pull out on the axle. This method worked 9 out of 10 times. Make sure you have a pallet or wood blocks for the axle & housing to fall onto. If it hangs up, more than likely the splines have a bur on them.
Post A Followup
: Re: Re: H bull gear removal
