Re: Live Power on Farmall M
Posted by Fred on January 28, 2004 at 16:28:40 from (65.56.192.91):
In Reply to: Live Power on Farmall M posted by Bart on January 28, 2004 at 16:18:12:
I have owned a couple of them that used the old belly pump for the tank. A hole is drilled and tapped into the bottom front, for a 3/4 pump feed line. You can use one of the side lines for your return connection. The guts are removed from the old belly pump as well. You pull the old pump drive shaft and put a plug in the hole. Works great.
Post A Followup
: Re: Re: Live Power on Farmall M
