Re: Re: Re: 460 Diesel starting problem.
Posted by Hugh MacKay on February 08, 2004 at 19:12:39 from (64.228.11.179):
In Reply to: Re: Re: 460 Diesel starting problem. posted by Grant on February 08, 2004 at 18:45:35:
Grant: It is a non idea, two 6 volt batteries hooked in series are 12 volts, two 6 volt batteries hooked paralell are 6 volt and two 12 volt batteries hooked paralell are 12 volt. You figure it out, one of the hookups aint going to work, while the other two hookups will each perform the same with the same total cranking amps.
Post A Followup
: Re: Re: Re: Re: 460 Diesel starting problem.
