Re: W6 stuck in reverse
Posted by Nebraska Cowman on February 14, 2004 at 03:19:11 from (65.172.142.105):
In Reply to: W6 stuck in reverse posted by Rob Johnson on February 13, 2004 at 20:59:52:
I have drilled out the hole to the next bigger size. (½ I think) You also have to drill out the little swivel piece inside. I never worry too much about welding, just make sure you hook the ground cable directly to the part you are welding on. if tou have a torch just cut the bolt off.
Post A Followup
: Re: Re: W6 stuck in reverse
