Farmall Tractors Discussion Board
Re: Re: Re: Can an IH 6v generator be converted to output 12v?
Posted by ltf in nc on October 15, 1999 at 17:19:27 from (206.228.213.168):
In Reply to: Re: Re: Can an IH 6v generator be converted to output 12v? posted by RED Blooded on October 15, 1999 at 15:50:36:
From your post, I gather that you are using a cutout on your 12 generator based on your statement that the wiring modification for installing a regulator was not required. For a tractor that is used sparingly this may be acceptable but is dependant on the amperage of the generator. On a tractor that is a work tractor and used daily a cutout could allow overcharging the battery. On minimum or no maintenance batteries this overcharging can cook the battery and blow the seals allowing the electrolyte to escape. Some of these batteries can not be serviced thus this shortens their life. I would want a regulator. The battery manufacturers also recommend using a regulated charger on todays batteries. Have you attempted to mount a Geo alternator under the hood of this model tractor? I would not cut the hood either. I have an original 5 window 37 Ford coupe and I appreciate your position on altering something that can't be undone.
Post a Followup
: Re: Re: Re: Re: Can an IH 6v generator be converted to output 12v?
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
