Re: 504 Clutch Problems Revisited
Posted by Bob on March 01, 2004 at 07:34:38 from (66.163.134.177):
In Reply to: 504 Clutch Problems Revisited posted by carl on March 01, 2004 at 06:58:32:
Warped, cracked, or mis-adjusted pressure plate.
Warped lined plate, loose rivets on lined plate, lining broken or frayed on lined plate. Lined plate cracked near hub.
Badly worn splines on transmission input (pilot) shaft.
Bad or dry pilot bearing.
Post A Followup
: Re: Re: 504 Clutch Problems Revisited
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
