Super MTA Electrical Question
Posted by Bob F on March 02, 2004 at 08:55:28 from (209.152.68.58):
I have a few questions on our Super MTA. First off I have to admit, I spend most of my time over on the green and yellow side of the website, so my knowledge of the red ones is kind of limited. This tractor has been converted to 12 Volts so it has a negative ground and an alternator. The problem is that the tractor starts just fine with the on-off button pulled out, but will not shut down with the button pushed in (even with the throttle shut clear down). I have been told that either there is some voltage leaking back through the switch or the switch itself is bad. I guess I'm looking for any ideas or guidance you folks may be able to give me on this problem. I'd also like to find a wiring diagram for this set-up if any of you know where to find one on the web. The harness on this tractor has been spliced into several times in the past and I'm not sure what I'm actually tracing when I look at it. I may have to start from scratch to rewire as I'd also like to reconnect the lights. I apologize that this post is kind of long and rambling and appreciate any assistance.
Thanks
Bob F
Post A Followup
: Re: Super MTA Electrical Question
