Re: Re: C123 engine overhaul max HP
Posted by Stan(VA). on March 09, 2004 at 05:41:20 from (208.59.156.207):
In Reply to: Re: C123 engine overhaul max HP posted by Red Rider on March 08, 2004 at 20:12:29:
Actually he can't if it's an original 140 block. They came from the factory as the equivalent of a C113 block with the 3" to 3 1/8" overbore kit already installed to make it a C123. Without doing custom machine work (and then finding custom parts) the best you can do is either get or save a set of firecrater pistons and use a new set of rings. The aftermarket TISCO pistons have a shorter piston and therefore a lower compression ratio. The good news is that you're not to far from your mark, look at 240 Utility HP numbers. Basically the same motor turning a little higher RPM (2000).
Stan(VA).
Post A Followup
: Re: Re: Re: C123 engine overhaul max HP
