Farmall Tractors Discussion Board
Re: Re: Farmall 400 Problems
Posted by Chad WInk on October 19, 1999 at 18:44:49 from (205.188.193.182):
In Reply to: Re: Farmall 400 Problems posted by Ludwig on October 19, 1999 at 13:50:18:
What do you consider a viscisity extender to be? If you use a good quality engine oil, you do not need to add anything to it.
The use of a semi-synthetic oil is of a limited value, when used in place of a fully synthetic oil. If you want synthetic use full synthetic.
As far as what to use in the winter, I wouldnt be a bit affraid to use SAE 10w. I had a Ford Diesel F-250 that I drove over 200,000 miles and thats all it had during the winter. Granted the synthetic is better that the 10w, but its also about $4.00 per quart and non-synthetic is about $1.00 a quart, and I honestly don't think you are going to see any benefit of using the synthetic.
Now to qualify all of this, I myself use Mobil 1 in my truck, but never saw any indication it was of a real benefit in these older engines.
Post a Followup
: Re: Re: Re: Farmall 400 Problems
