International 354 identification
Posted by Greg on March 15, 2004 at 19:36:19 from (65.56.121.234):
I am considering buying an International tractor from a friend that we believe to be a model 354. All decals are worn off and even he doesn't know what it is exactly. It is a 4 cyl. diesel and looks to be around 30 years old or so. Has a hyd. steering cylinder located not under the steering column but outside the tractor along the steering mechanism. Also has 2 "back-to-back" hydraulic pumps gear driven by the engine. One for the 3-point, one for the steering. I would like to positively identify the model - will the serial #'s help me do this? If so, where are the all located? I realize this isn't much info but I simply need to know what to look for in terms of #'s and design to help me find out exactly what model International this is. Thanks for any information.
Post a Followup
: Re: International 354 identification
