Re: Re: Zenith Carb, Got some questions!
Posted by Tommy H on March 20, 2004 at 19:01:04 from (65.140.19.166):
In Reply to: Re: Zenith Carb, Got some questions! posted by CNKS on March 20, 2004 at 18:49:24:
Ok, Ill describe it to you, sitting in front of me.
ok. The intake is facing my right, as it came off of the tractor.
Starting on the left-going right.
Sticking straight out, on the bottom of the bowl, there is a T-handle adjuster, It is a needle. This needle faces the front of the tractor.
Going back, on the back of the carb, facng down there is a petcock, or a drain cock? Not a needle.
up top, there is a needle, facing at a 45 degree angle down into the carb, it has a flat head on it.
The float on the inside is seperated into 2 seperate bouys.
Gasket was destroyed upon disassembly.
Post a Followup
: Re: Re: Re: Zenith Carb, Got some questions!
