Re: Re: Re: Farmall H Starting problem electrical
Posted by Bob M on March 22, 2004 at 13:04:10 from (165.170.128.66):
In Reply to: Re: Re: Farmall H Starting problem electrical posted by Pat Connors on March 22, 2004 at 11:59:35:
OK Pat that’s different! Here’s how I’d proceed: 1 – Fully charge the battery (stick the charger on it and leave it on the low setting overnight) 2 – Attempt a start. If it spins OK, you know just the battery needed charging. However if it still has trouble, problem's gotta be either high resistance somewhere in the starter power circuit, or the starter itself is bad. 3 - Do the easy stuff first: Clean the battery cable terminals – especially where the grounded cable bolts to the frame. Make sure it’s on a solid frame or engine block (NOT to sheet metal like the battery box)…ideal spot is under a starter mounting bolt. Check also the battery cables for damage – they can look good outside but be corroded nearly through under the insulation. 4 – If it still cranks slow, immediately feel around the battery cables, connections and starter switch after attempting a crank. The high resistance area will be noticeably warmer than the surroundings for a while after you crank. Or if you have a good voltmeter, take voltage drop readings one at a time across both battery cables and across the starter switch WHILE CRANKING. Any reading greater than about 0.2 volts while cranking means that component has an excessive voltage drop and should be replaced. All the above of course presumes the new battery you bought is good (not always true, especially for 6 volt batteries purchased from a place where only a couple get sold a year). Good luck!
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
