Re: Re: Farmall M Oil ?
Posted by Andy Martin on March 27, 2004 at 19:34:21 from (67.248.199.164):
In Reply to: Re: Farmall M Oil ? posted by CNKS on March 27, 2004 at 19:15:01:
I agree. Modern oils are much better than what the engine was designed for. The big bearings and low pressures and temperatures let you use about what you want. Much has been made of having trouble if you use detergent in an engine which has used non-detergent oil it's entire life. I always switch a new tractor to detergent oil and have never had a problem. In fact I have a 1939 that has so much sludge in it you have to poke a wire in the drain hole to get the oil to drain. After several changes it is about cleaned out (it gets changed once per year). The average old Farmall you buy has probably not been changed or even checked in years. Our tractors get worked in hot weather and cold, we run 20W50 year round with good results. Several of our engines burn oil under load and the 20W50 helps. We use drainings from all oil containers in squirt guns and oil bath cups. This includes motor oil, automatic transmission fluid, gear grease, and hydraulic fluid. We get good results with hydraulic fluid in belly pumps due to switching implements between tractors, but in our mowing M we had to go to 30W in order to pick up a nine foot swather with a worn belly pump. Don't be concerned if you drain clear water out of the rear end.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
