Re: 300 Electrical Problem
Posted by Mark Witt on March 29, 2004 at 10:46:38 from (65.216.75.240):
In Reply to: 300 Electrical Problem posted by Dave K on March 27, 2004 at 12:04:57:
Dave: By "starter switch", I assume you mean the solenoid with the + cable from the battery going into one side and the cable to the starter coming out the other side, and each cable attached with a terminal, stud, and nut. If that's the case, the most common way I've seen these bypassed is with a pair of pliers. Or you can use jumper cables instead. - Turn off the ignition switch. - Disconnect the coil wire. - Put the transmission in neutral. - Set the brakes. - Leave the spark plugs in to give the battery and starter motor a realistic challenge. - Open the pliers until the handles are far enough apart to span both battery cable terminals on the solenoid. - (Did I mention turning off the ignition switch, disconnecting the coil wire, taking the tractor out of gear, and setting the brakes?) - Press the plier handles to the terminals so current passes directly from the + battery cable through the pliers to the starter cable. Now the switch is bypassed. No activity (or slow starter motor)? Check the battery, starter, and cables. If the starter works fine, put the pliers away and actuate the starter switch (with the tractor still disabled). If the starter doesn't move and you don't hear a click from the solenoid, then either the solenoid isn't working or it's not getting a signal. Pull one of the small wires off the solenoid (or maybe there's only one, I don't remember). With the starter switch not actuated, the wire should have 0 volts. With the starter switch actuated, the wire should have (in your case) 8 volts. If not, you're not getting the right signal from the starter switch. If the signal is good AND it's attached to the correct termial on the solenoid, and the solenod's not clicking, then the solenoid is bad. I doubt you have a bad solenoid. In my experience the solenoid either works great or not at all, so the slow cranking you described would not apply here. Maybe other contributors have had diffeent experiences, though. Another thing that can cause problems with starters is that they can sometimes bind if you install them just a hair off from where they "want" to be. Again, I don't think this is your problem, but if you've had the starter off you may want to loosen it just a little and re-tighten it. You can measure 8 volts somewhere, but you still may not have meaningful current available. If you have a problem like a rusty, dirty, or loose cable connection (on the ground side or the non-ground side), it can pass a few milliamps or even microamps -- enough to make your voltmeter happy. It won't do a thing for your current-hungry starter, though. Make sure BOTH ends of all your cables (battery +, battery -, and starter) are clean and tight. Good luck. Let us know how it turns out. Mark W.
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
