Re: Re: 300 Electrical Problem
Posted by Dave K on March 31, 2004 at 21:35:06 from (66.82.9.59):
In Reply to: Re: 300 Electrical Problem posted by Mark Witt on March 29, 2004 at 10:46:38:
Mark:
Many thanks for your very informative reply. By starter switch, I was referring to the key switch which one normally turns to start the engine. It is attached to the small terminal on the top of the solenoid. I have tried every thing you have mentioned to no avail. I have pretty much ruled out a faulty solenoid by taking the starter back to the rebuilder who showed me that it works. I question my ground from the battery terminal, but I still had no luck when I grounded it with a jumper cable from the positive terminal to the block. I am now of the opinion that the answer is covered in your last paragraph. Maybe my 8 volts reading belies the fact that I don't have much in the way of amps. I just thought I would still get a click from the solenoid. My next effort will be to try to get some diagnostic help by running a jump from my always trusty starting JD MT.
I have taken all the precautions you mentioned except for removing the coil wire; why is this neccessary?. Your input is greatly appreciated
Dave K.
Laurel, MT
Post a Followup
: Re: Re: Re: 300 Electrical Problem
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
