Re: Farmall Cub is a QUITTER!
Posted by 49 Cubber! on March 30, 2004 at 14:34:17 from (206.74.216.173):
In Reply to: Farmall Cub is a QUITTER! posted by Robert in AL. on March 30, 2004 at 14:19:17:
You proably are doing this but you are lifting the brake pawl aint cha?:)Check the gov. spring and make sure it hasnt broke of come loose and check the linkages too.I had the pin come out of the linkage and it acted that way.
Post a Followup
: Re: Re: Farmall Cub is a QUITTER!
