Farmall H bolster bushings
Posted by Ken on March 30, 2004 at 14:45:59 from (67.50.133.235):
Has anyone replaced the lower bushing and bearing in the upper bolster? If so does the stem and associated parts go in as a unit or does it go in a seperate pieces? Seal ring/bearing/bushing/steering stem. And also whats the easiest?
Post a Followup
: Re: Farmall H bolster bushings
